For installing the doors, Double Venom has a great write up that will save allot of time in alligning the doors up. Follow that and you should be able to mount the body and allign the doors... Doing it this way will probably take 12 hours (+/- 6 hours) depending on how confident and how well you understand the process.
I used a body saw to cut the door webbing which worked good... If I were to do it again, I would use masking tape to create a trace line to cut against (which would help make the cuts even more straight).
