Dwight,
I'm running a 347. It has EFI from a company called MassFlow. It basically is Edel Vic Jr intake that has injector bungs welded in the ports, and has a throttle body designed to resemble a 4 barrel carb. The air cleaner looks like a 60's era aftermarket chrome filter. Inside the air cleaner is a GM MAF meter. It has a stock EEC4 A9L computer. There is a MassFlow designed converter between the GM MAF meter and the Ford EEC4.
I am considering going back to a Ford MAF meter, but may want to go back to the MassFlow setup. So I was trying to figure out if the is a unit I can pick up at the local salvage yard fairly cheap to experiment with. I want it to be sized big enough for my engine. I also need it to be fairly common, in order to find one at a salvage yard.
Rick
