Old 10-19-2012, 06:51 PM
olddog olddog is offline
If you want a 60's erra look, linkage is the way to go, but be warned. When a motor mount broke, the engine would raise up and pull the throttle open. I have seen many remedies. Drill the mount and put a bolt through it, chain between frame and engine, etc. If you go linkage, make sure engine stays put when a mount breaks.
