Originally Posted by hinoonaz
I don't rev the engine hard very often. The typical on ramp to 5500 and no power shifting. I put on V-groove pulleys and did not realize the underdrive situation. The odd point to me is that the temps anywhere else on the engine, hoses and radiator are 165 to 185. Going in and out of the radiator. Just seems odd to me that only one spot the water temp is this hot and that is at the temp probe in the intake. Thxs for any advice.
Most of your problem lies with your pulley set-up!!!!!!!!!!! For anything but all out racing your crank pulley should be at minimum the same diameter as your water pump pulley or 1 to 2 inches LARGER in diameter...........you want to overdrive your water pump by 15 to 25% for street driving.......
Ditch the underdrive pulleys and you'll see your problem disappear........
David
