Originally Posted by patrickt
Take it for an attempted drive with the tunnel off. With the "clutch slipping" badly, look back and down at the driveshaft. If it's spinning hard, then the rear needs rebuilding. ERA uses Michigan Driveline Michigan Driveline Products
Unfortunately that's gonna be tough. The CSX frame and the large Lakewood bell (serious PITA to remove), combined with a few leak issues I wanted to address (changing
oil pan and replacing gasket on remote filter block plus properly helicoiling a pan bolt hole), means the engine is on a stand as of yesterday.....
www.partskeeper.com
