Old 10-25-2012, 09:55 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Default Plug wire routing
I've read a couple of threads about the pros and cons of routing plug wires over the valve covers vs. running them around the front and then down the sides of the valve covers.
From an originality standpoint the photos I've seen indicate that, for both big block and small block cars, the plug wires were typically routed over the valve covers. Not sure if that was always the case, or it just doesn't really matter (again from an originality standpoint). I'm certainly not an originality expert so wanted to put this out there for your thoughts.
Regards,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
