Old 10-27-2012, 07:07 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by jonalley View Post
"..........I'm trying to get to the syncing stage but have the very low number draw on the front carb to adjust against. Should I try to bring the others three down to that number??......."
reading on I see you have a compression issue, but for healthy engines it doesn't take much adjustment to bring up the vacuum readings. A quarter screw turn can be the difference between zero and "all balanced".
Z.
'65 K code Mustang
'66 Galaxie 500
