10-30-2012, 08:11 AM
WA
Cobra Make, Engine: Contemporary Classic 427 S/C, Full Roller 429ci Super Cobra Jet, RHP Flowed BlueT & RHP Cam, CompCarbs, AirGap, V12 E-Type Jaguar F+R, 4SBBTL
Sure sounds like a bad alternator. Depending on where your alternator is mounted you may be able to put 12VDC directly from the battery in to the alternator windings and manually force your alternator to crank full amperage. Pretty much a bench test on the car. Coupled with watching your Volt meter you should see those 12.2 numbers jump up to the mid-13 to 14 VDC range. A healthy battery at rest fully charged should volt meter about 13+ volts.
"Most barriers to your success are man made. And most often, you're the man who made them."
