Just note a garage floor or driveway is not level. It does go uphill to allow for drainage.
Take a laser level and check the drop from the point where the front wheels are sitting and noted the amount of drop to the rear wheels. Use a board to shim the rear tires off the floor to get the car absolutely level, then perform the magic.
You can also compensate for the drop by moving the tape on the wall. Just need to do so geometry to get that number.
Sometimes things really do go as planned.
