Originally Posted by strictlypersonl
#9: You should have the high beams on, not the low beams. The low beams will end up lower and to the curb side when the lights are properly aligned.
E-How: Headlight alignment
E-How did not ever adjusted a headlight - the adjustments are done on low beam. The adjustments make sure you don't blind oncoming traffic. The whole reason for this exercise.
Skuzzy, as long the floor to the wall is not more than 15 degrees off the floor it makes no difference.
