11-01-2012, 11:47 AM
BC
Cobra Make, Engine: CAN-AM cobra, 460 SVO
Originally Posted by Cobra #3170
Lets see, there have been approximately half a billion cars sold in the US since direct throttle linkage was dropped. There have been instances of throttles sticking for sure, but a tiny percentage of total vehicles produced.
Throttle cables must be routed correctly observing minimum bend radii and staying away from high heat sources. They are extremely reliable when installed properly with far fewer moving parts than conventional linkage with rod ends and clamped arms that can slip on shafts. Drive by wire is even better if you can program opening rates but if you can't, linkage would be a
2nd choice over cable. I can see using linkage on a show or concours car that must be absolutely correct from a judging stand point. Conversely from a functional stand point they can be very trying. My linkage broke at the arm that mounts on the pedal cross shaft in 1966 when the car was new. I then had a series of slippages on linkage arms till I welded then to the engine to body cross shaft. I broke a motor mount at an autocross in the late 1970's that gave enough throttle to slide the front wheels and over ride the rear brakes while headed toward a group of people at the finish of an autox. Turning the key off saved the day, it wasn't full throttle but it was enough.
Slowing down the throttle opening rate really improves car control unless you are dealing with less that 400 HP where you probably don't need it. I would bet that some of the accidents that have occurred with Cobras over the years could have been avoided with a long pedal slow opening throttle.
Personally, I would much rather have a car that is drivable over a car that is eye candy but that is an individual choice that only you can make.
3170, Do you happen to have a picture of the cam setup you can share with us? I like that idea of more travel on the gas pedal.
Mark
