Ok so I got the switch, but it doesn't seem to have 2 distinct circuits in the right order. I have 3 wires coming from the wiper motor, red, blue, and green. Red and blue are High and low, with Green being ground. Ground the green and put power to either red or blue, viola, wipers.
My question is does anyone know which lucas switch I can get that will operate the wipers so that the bottom position is off, middle is low, and top position is high?
It appears that the SW switch I have will go off in the middle, then turn the wipers on in either the up or down. I can also wire it so that the low is on in the middle, and high is the up position, but to do that, in the H position, there is power going to both H and L, and the wipers seem to not run at their fastest... don't really want to do that, I would expect something to burn out..
Jim
