  #47 (permalink)
Old 11-05-2012, 01:09 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by fordracing65 View Post
I think oil consumption is obvious different from car to car, build an aftermarket engine with any power adder, turbo, supercharge, or nitrious and use a carb and then use efi and then come talk to me, efi is far far superior, Kyroyer engines builds some of the finest efi engines around at a cost but they work like a dream, its a fact carbs work, efi works better, not these self learning systems I mean real tunable efi...
You must read posts more carefully. I didn't say carbs are superior to EFI.
You said bad EFI setups are better than carbs. I said most folks would argue that point.
I said that there aren't many, if any, on ClubCobra with EFI that works properly 100% of the time.
And I said if they work properly, look good aesthetically, and aren't priced stratospherically, then I'll buy it and install it.
How many here on ClubCobra with a Kroyer or "Kyroyer" engines? Please let me here from you. Do you have EFI? How's it working for you?
