Old 11-05-2012, 12:49 PM
john chesnut john chesnut is offline
I would change springs to longer ones. Short springs often suffer from coil bind. If the suspension is engineered properly, and the correct parts are used, the spring should be under compression (albeit slightly), even at full droop.
I would also check that the shock is the correct length. At ride height there should be 60% of the shock travel available for compression. Just my 2cents.
