Old 11-06-2012, 04:30 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Originally Posted by Tommy View Post
Dan,
I don't have your solution, but I do have one thing to keep in mind as you search for one. People often focus so much on the size of the air filter that they forget to consider the size of the gap between the top of the carburetor and the top of the air filter. As that gap gets smaller, there is less space for the air coming through the air cleaner to be drawn into the carburetor. This can limit air flow as much as a smaller air filter. This is particularly important on large, high performance engines.
Drop base filters create this situation. ERA provides a 14" drop base filter with the center plate that fits on the carb detached from the base. You then measure the clearance you have (putty works well for this), leave 3/8" clearance for engine torque and then weld the plate to the base at the highest point. This gives you a custom fit with the largest gap possible.
Regards,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
