It should be close to flush with the inside of the lip in the hood area. At least mine is anyway.
added info:
I believe that it is tilted forward because that way when you install the body and pull it back into position the firewall lip presses on the hood lip to create a seal of sorts.
If you put foam tape or a bulb seal of sorts on the upper part of the firewall lip it helps the sealing and also helps body vibration/shake a bit.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Reason: see added info.
