The individual orange wire nuts are not intended for automotive usage. You would be well advised to eliminate each of them with a fresh wire run of the correct gauge into each of the end multi pin connectors. Keep in mind that each wire break and connector is a potential trouble spot. Solder and heat shrink at each terminal end will go a long way to avaoid what happened previously. You are doing a good job, wiring is very satisfying when completed.
Put heat shrink tubing or tape the Male/Female spade terminals use for the parking lights wiring. Eliminate any potential for moisture to gain entry.
Rick
