Old 11-12-2012, 06:46 PM
byron w byron w is offline
Cobra Make, Engine: shellvalley 428 ford
If you cut off a coil then you need to try and flatten out the seat. You can file or grind it. You can also find rubber insulators for Mustang II or Pinto front suspension at Speedway Motors, the hot rod supply house. They are a great source for parts. also, at very little cost you can get new springs for your application from them too.
Good luck,Byron
