SOLUTION UPDATE
B&B did call back and we discussed the situation. There was a short period of time that B&B contracted out their metal fabrication. It turns out that mine was one of a few cars that the lower shock mount on the axle was made to high. The solution is to weld a new tube on the bottom of the bracket where it narrows and that will put the shock at the proper ride height.
B&B will send me the metal tubes and I will weld them in.
I think this is the most reasonable solution.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Reason: correction
