Thread: SPF Soft Top
Old 11-14-2012, 01:19 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The softtop comes in a protective pouch. Along with the softtop, side curtains are included, both also in one pouch. There should also be a set of steel bows, a left half and right half, each section also provided in a seperate pouch. The top, side curtains and tonneau cover became options at some point, so all chassis may not have them. The pouches should all have your chassis number written on the inside. Even thought they are pretty much interchangable, each is fitted at the factory. Older 2 bow tops and tonneau covers only used Lift-a-Dot fasteners and the newer style 3 bow tops and tonneau covers also used 2 Tenax style fasteners. Newer tops were made of a canvas material with a zip down rear window (3 section), older tops were on piece ands made of vinyl or some such material (one window). Drop me an email (see below) with photos of what you have and I'll be happy to confirm you have everything. Newer style top became standard at approx chassis #1416 so you should have the latest version. I have some folding directions and a few hints for the newer style top.
SPFWiringDiagrams@Comcast.net
