Sorry, the engine is out and all apart. I say not possible because with the large valves and longer stem length, matching the installed height of the softer springs to the valve is the challenge. They are about .090 different. Years ago you use to be able to buy all different widths and depths of retainers. Maybe someone knows who still does.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
