We are staying with the solid roller that it has. At this point it looks like we may just be getting a slightly milder cam. Compcams says they can do a custom grind on one that will calm it down and make it more reasonable for the street. They say we can still use the springs we have. I am waiting to see what the specs are.
Compcams checked the serial number on the cam today and found out it has been reground once already. So it's a new cam.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Reason: Last sentence added
