Old 11-18-2012, 11:09 AM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Out of the ERA manual for the Jag based rear - "The ride height will change roughly equal to the collar height change."
So if you put a 1/2" spacer in all 4 shocks, you should get a 1/2" ride height increase.
I don't see any reason a small spacer would not fit if you used a proper spring compressor. 1/2" is pretty thick.
John
