Old 11-19-2012, 04:49 PM
patrickt patrickt is offline
Originally Posted by cobrabritt83 View Post
i need to get a new crankshaft for my 427, I have seen a lot of people using a 428 crank. I know a 428 crank has a longer stroke then a 427 but what all do you need to change in a stock 427 to use a 428 crank and is it worth it.
The only reason for putting a 40 year old 428 crank in your FE is if you already happen to have a 428 crank hanging in your basement. If you don't, then you should get a new stroker crank... along with new rods, bearings, pistons rings, etc. There's a slight debate as to how much stroke is the right amount.
