Originally Posted by Tutosnake
May I throw another two at you guys?
1- Has anyone sprayed Rhino Lining (or the equivalent) on the wheel wells of his car (to reduce noise and damage)?
2- Does anyone know what kind of screws can be used for fastening the SAI CSX number plaque to the dashboard/transmission tunnel?
(Now, I am not completely sold on using the plaque in my car, but if i do, I want to be ready)
Hector
1 - Your wheel wells should be lined with aluminum, right? They protect the underside of the wheel wells and you shouldn't need Rhino lining. HOWEVER, if you haven't already put the clear adhesive spats on the outside of the wheel wells in the area near the door opening to protect against stones thrown by the front wheels, now is a good time. You can't really do it when the paint is no longer smooth (wish I had known that).
2 - I used two sided trim adhesive to stick my plaque to the dash so I could remove it if I wanted to without putting holes in the dash. I filled the holes with rivets that don't extend deeper than the plaque so it looks attached. If you want to screw it to the dash or tranny tunnel, small sheet metal screws will work fine.
www.partskeeper.com
