Those caps you found look correct and are breather caps. With that PCV set up you have and the two breather caps that should be fine and look good.
Like
Mick,
Are you looking at the right photo? The way I read it, the second photo is how the car is set up now. The
oil cap on the driver's side valve cover doesn't look like a breather to me. If the other side is the same, air can't be drawn into the crankcase and pressure will build and
oil will start seeping out and blowing down the intake from the pcv valve.
