Mickmate, better than the one I was thinking of and should work fine.
I found the old one. If I remember right some of the big FEs had two ventilation systems. The crankcase can create a lot of pressure. I can't remember how the other one worked.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
