Last week I noticed a small pool of
oil around the front most bolt above cylinder No. 1 on the intake manifold and another small pool of coolant in the valley of the water pump as noted in the photo, the photo was taken after I cleaned the affected areas. I'm looking for an analysis and most likely a confirmation that I have a leaking intake manifold gasket. I've long suspected there may be a leak as the No. 1 cylinder spark plug has a slightly lighter color than the other plugs but, I have been unable to confirm this using the carb cleaner, propane or WD 40 methods.
I retorqued the intake manifold bolts, but the leaks reappeared after about 200 miles. There are no leaks while the engine is running, they appear overnight. No coolant in the
oil and no smoke/steam from the exhaust. The engine runs strong and has acceptable idle for the installed cam.
The intake manifold is a RPM Airgap and heads are Brodix 5.0 STR.
Brodix recommends Felpro 1250 gaskets; are ther better ones available?
