Old 11-30-2012, 06:20 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
This is like a what color is the best question. Are you driving around town more or on the freeway. The E-303 cam has 220-220 dur. at .050. It's power band is a little higher, but it's not a high RPM cam by any means. You could go either way. These are the numbers.
Trans ratios for most T-5s
1st 3.35 after market 2.95
2nd 1.99
3rd 1.33
4th 1.0
5th .68
5th gear RPMs @ 65 mph with 295s with a diameter of 25.65"
3.08 1775
3.54 2035
3.73 2175
4th gear RPMs @ 65 mph with 295s with a diameter of 25.65"
3.08 2635
3.54 3000
3.73 3200
You choose.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
