Old 12-04-2012, 01:10 PM
GBowman's Avatar
GBowman GBowman is offline
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Default Carb problem-I think????
I am experiencing what seems to be a flooding issue. Dead cold start everything is fine-1 pump, choke closes, warms up, touch gas and idles perfect. If I go to start the car after it has warmed up and then sits for a short time it wont start and if I give it gas it sputters and white smoke bellows from the carb. The only way I can get it started at this point is to hold it wide open and play with it, once it starts it runs great.
I checked the float sight glasses, fuel is just above the bottom of the glass. No visible fuel leaking when I look into the carb after I shut it off.
Any ideas? Thx
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
