Lower the floats until fuel is at the BOTTOM of the window while idling. Fuel is probably dripping out of the boosters or accelerator pump jets after setting for several minutes. If you want to check: after shutdown carefully force part of a paper towel carefully past the booster and above the throttle butterfly. Remove it later with a set of needle nose pliers or fish it out with wire. Check it for saturation of fuel.
Rick
