I have 17's with Nitro 555's for touring. I will have 15 steel Knock-off's made by Vintage wheel. Then I will put M/T's skins on them. I use a 3.08 for touring, and change the finals to 3.55 for track. It is important to me that the total height is less than 26.25 inches or less. I use a TKO 600 with .82 fifth. The rear end is by Currie, in 9 inch, with and Auburn Ratchet spool. Wilwood brakes, 11 fronts and 12 rears. I also use a Ford 350 p/u truck Master. My motor is a 460 BB, 740/680. Lots of trick stuff in the block, and heads.
