After the engine is warm, before you start it again look at the sight plugs and determine if the fuel level has dropped. If it has then fuel is leaking into the manifold. It could be gaskets or a leaky power valve. If you pull the carb also check for loose or missing screws on the bottom of the throttle plate to main body.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
