Hi Steve, Jeff told me that you were in touch. BTW, his A/C problem is with the evaporator or expansion valve, not the condenser. He's passing cold liquid refrigerant out of the evaporator so the refrigerant is not sucking heat out of the circulating air as it is obviously not evaporating. The give-away was in some photos he sent me and I saw that return line from the evaporator to the compressor had frost all over it. Condenser problems are the exact opposite where you typically can't suck heat out of the refrigerant to get the compressed gaseous refrigerant to liquefy. Best, Ron
