Originally Posted by FWB
is there a port on the primary metering block? that's where it should be pulled from
I don't believe there is one there. I may be able to swap for another metering block, though.
If I can't tap vacuum there, would a spot under the carb on the spacer, or into the intake plenum under the carb work?
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
