Old 12-09-2012, 10:48 AM
MRGEORGE077's Avatar
MRGEORGE077 MRGEORGE077 is offline
Cobra Make, Engine: Shelby American CSX 8000 Slab Side series, 289 High Pro , Eight Stack EFI system ,TKO500
That's a pic of a semi-tubular rivet that I thought would fix the OP up by slipping over the shaft of the broken holding pin along with a little JB Weld. Here is a pic of the holding pins as they are seen on the the soft top frame. Mickmate has them in stock, but if you call them "holding pins" he will charge you a premium.
I understand completely, from now on they will be called semi-tubular rivet, thanks for your help I appreciate it.
Participating in a gun buy back program because
you think that criminals have too many guns
is like having yourself castrated because you
think your neighbors have too many kids.
