Old 12-09-2012, 11:07 AM
patrickt patrickt is offline
Originally Posted by MRGEORGE077 View Post
I understand completely, from now on they will be called semi-tubular rivet, thanks for your help I appreciate it.
But you can only use a semi-tubular rivet if part of the old holding pin is still sticking out. If you managed to break it off flush, then I think I'd just drill it out and use a Double Capped Screw Rivet in there -- you could put that in with your fingers and a little thread lock. That would be really easy to do. Personally, I always like to take the easy fix if possible. And if it's at least partially half-ass, that's all the better.
