Old 12-10-2012, 12:52 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Hotfingrs View Post
Better check your Holley book again, a blown PV will also let fuel come out the boosters.
Can't see how, even if the power valve is open, the PVCRs in parallel with main jet is the same as the total areas combined.
A blown power valve feeds fuel directly to the intake manifold, via the vacuum channel in the throttle body.
The bowl drains into the motor at shutdown.
Excessively high float level IS THE ONLY WAY fuel can run from the boosters.
All carburettors will have this problem with an uncontrolled float level.
Gary
