Hold on. Before you go ripping things apart, take the back of a screwdriver, (the one you are going to use to set the floats and adjust the idle) and tap the top of the needle and seat. {good taps) you are not going to break anything. Then try again. This usually loosens the needle from the seat. It could be debris but usually just a sticky ingredient in the gas that has dried. I've seen this alot in race cars that sit.
Lou
Lou
