Old 12-11-2012, 05:37 AM
jcraigau's Avatar
jcraigau jcraigau is offline
Cobra Make, Engine: G-Force Mk1, LS1, T56, Jag S3 suspension
Default Brake Booster and Master Cylinder
Hi Guys,
I'm at that point where it's time to find out all about the exciting world of braking, which I'm quite passionate about.
If it doesn't go that's a small problem, if it doesn't stop, that's a huge problem!
The "build manual" has the following one line in total "Ford master cylinder, with Sigma booster" - Handy!
So I'm open to ideas as to what others have used...
From the research I've done I need a S230mm PBR VH429 2 stud front can.
Then I found that the VH429 was replaced with VH415R.
Thanks,
JC
