Dan,
I am running new Edelbrock Alum Heads when I installed one side the push rods just to see if I liked them the push rods were shorter (although I could make up the length with the adjustment). When I set each valve they seemed to be loose ie: too much play on the valve springs. Even though I had put the preload on the lifters there seemed to be to much movement in each rocker arm when each valve was closed, so I took them off. I am still trying to decide which to use.
Did you use adj push rods w/ your bigger hydraulic cam?
"Let's roll"
"Be part of Something Good
