Old 12-15-2012, 06:45 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
The nine inch ford rear has a pretty low pinion center line compared to the 8.8 and other rears--In order to have most favorable pinion u joint angles, ride ht travel upwards will be more restrictive in almost any application-------However since in your case, the tires set on the ground and the chassis travels downward, not suspension upwards, soooooooo
To get the ideal rear combo might entail resetting drive line angles with the rear tyrans mount-------and then there will be the issue of side pipe alignment----------
Have a very merry Christmas season!!!!!!!!!!!!!!!!!!
