0.3V seems much too low, even at the load side of the ballast resistor. Are you measuring across the ballast resistor, or between the wire and ground? (the correct way...)
Is there 12V at the G/V wire?
At any rate, you should connect the G/V wire directly to the Pertronix if they recommend full voltage.
