Old 03-08-2002, 12:06 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
The decal is a great idea > Who supplies that?My current master switch is on the positive side on firewall reach up under the dash and flip it .But I cant reach it after getting all belted in,What a PAIN.
Currently I'm planning on putting a Master cutoff switch on the trans tunnel where I can access it easily in full view but on Negative side of the circuit.That way A flash from a short wouldn't be a problem in the event of the trans or something else moving. Why would you get away with a smaller cable on negative side of a circuit ?What goes out has to get back in. The smallest cable any where in the circle would become the limiter.They call it a circuit.
Can you emagine all the switches a guy would have to set or check if every sanctioning body were obliged?
Mike H
