How is the cut-off switch on either the positive or negative side of the battery going to kill the motor if the motor is already running? The alternator will keep providing power and complete the circuit. You can completely disconnect and remove the battery once the motor is started and the motor will keep running. Granted you won't be able to re-start it.
