Old 03-08-2002, 05:01 PM
Whaler Whaler is offline
CSX thanks for the advice...I did not know that and did not think there was much more than gravity feed pressures to worry about...the backing nut on the actual braided hose fitting does quite a number on the connection as well.
I couldn't see the teflon liner collapsing as it would be supported by the inner push-on...
Was an uneducated suggestion..
Where most will be screwed is that the reservoirs have only the plastic male nipple Going to a braided hose adaptor could be interesting....the masters also have the same cheap plastic fittings and bowl caps
Thanks
Tim
