Originally Posted by 428street
Thanks guys. I was thinking about some rubber rings as well. Any info on those, i.e., where to get them. My issue is not that I don't know how to put it back together but I can't screw the double threaded piece back onto the nut that goes inside the can. The red material just will not allow me to start the threading process. I'll fiddle with it a bit. I just had to walk away from it.
If you're trying to do it wih the hard line and double threaded piece still on the car, I think it's going to be tough. If you are working off of the car, I can't remember for sure but I may have used a pair of oversized, long needle nose pliers to hold the washer and then the nut while I threaded them on to the double threaded piece.
