Old 12-25-2012, 08:48 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default dailey dry sump fitting in jbl
here is a pic of the pump with rearward facing -16 outlet, a 45 degree off it will not work because it hits the threaded tube, but a 30 possibly and a straight for sure. much better room in my case. if unused dailey accepts the parts back in exchange, cost would be about $160. there is about 2 1/2" from bottom of pan and bottom chassis, plenty of room and really cleaned up from the previous setup. there is also an air/oil seperator on the tail end of the pump.
some pics of fire sleeve bought from aircraft surplus at about 1/3 cost of the sleeve, steel braided hose with fittings is free but unfortunately the ends have to be cut off. the smaller lines are rated for 1500 psi, i bought a -16 line that was rated for 750 psi.
