Hotfingrs has an automatic transmission, which makes a difference. It is quite street-able, but I would say the engine is radical.
You may want to ask what type of tires are used at the track. How much power you can hook to the ground has to do with tires, and weight transfer (suspension setup is a huge factor). The average IRS is not going to hook up as much power as a ladder bar straight axle, for instance.
