Old 12-31-2012, 02:49 AM
Zedn's Avatar
Zedn Zedn is offline
Gday Stan,
You can see my mounts in the walk around video i posted in my progress thread below. I made a small frame to mount the seat belt retractor inside the boot. It bolts through the body and into some mounting brackets i welded on the chassis. I welded in some additional cross members to bolt seat mounts and seat belts to. The NCOP VSB 14 provides guidelines for designing your seat mounts and you should also discuss with your engineer. Most seat belts use 7/16 bolts which will come with the belts.
The seat belts part numbers can be found on the Klippen website. It all depends on the seats you use and the location you mount the retractor. The locking mechanism is different depending on the angle it is mounted. You can get vertical, horizontal and in between. The stalk length will depend on your seats. You need a stalk that places the buckle approximately at your hip so hence the seat height will make a difference.
Send me your email address by PM and i will email you a document i prepared for my engineer. It includes photos of each mount and dimensions. Since our chassis are very similar you can probably do the same.
Happy new year.
Liam
